iSearch 1.2
iSearch 1.2
Post by Info-Mac » April 24th, 1998, 9:00 am
Download: http://archive.info-mac.org/text/isearch.hqx
This is a very handy utility for anyone who works with text.
iSearch lets you do boolean and literal text searches thru
files, folders disks, and CD's. iSearch has an accelerated
search engine, that can work equally fast in the
background while you carry on your work. iSearch uses drag
& drop to define search locations and remembers the most
frequent locations used in a Œsearch in:¹ drop down menu
list.
Changes & additions in 1.2:
€ Corrected conflict with contextual menu extension.
€ Added Drag & Drop finder folders (to add to folder menu)
€ Added Boolean searches to:
- find all of several space delimited words
- find at least one of several space delimited words
- find text literaly (same as before)
