Gammasoft WordProc
Gammasoft WordProc
Download: http://archive.info-mac.org/text/gs-wordproc.hqx
Here is a small word processor. Features are (yes, ARE) word count and
spell checking. Word list for spell checking is not included. Now that
spell check is done by XFCN, it shouldn't be the horribly slow one from
Gammasoft Office.
This file requires the Gammasoft Runtime Engine. If you don't have the
Gammasoft Runtime Engine, you can download it from this server or, if you
have MacOS Easy Open enabled, use the HyperCard Player instead.
When you decompress this file, be sure to put it in the same folder as the
Main Menu file. Also put an alias of the Gammasoft WordProc file in the
`Data folder. Make sure the alias doesn't have an " alias" suffix or a
space after it's name.
