Download: http://archive.info-mac.org/text/find-in-files-20.hqx
Find In Files 2.0 searches a set of files (or all files) for some text.
Why would you use Find In Files? Here's an example: Suppose you have a
bunch of HTML documents, and one or more of them has some information you
need. You could open every one of the files and search them by hand, or
use Find In Files to search for you. Simply enter some key words in the
"Search For" text area, optionally enter a creator and file type (or click
the Select File button, and open any file to get the file's creator and
file type), select the folder where the search begins, and click on Search.
M A U I S O F T W A R E
189 Auoli Dr.
Makawao, Maui, HI 96768-9313
http://www.mauisoftware.com/
mailto:[email protected]
