Convert Celtic (Welsh) RTF files Mac <-> Windows 95
Download: http://archive.info-mac.org/text/convert-celtic-rtf.hqx
This package contains mapping ("translation") tables for both
Add/Strip (info-mac/text/add-strip-322.hqx) and
PowerReplace (info-mac/text/power-replace-63.hqx).
These tables enable you to convert RTF files with Celtic (Welsh)
characters between MacOS and Windows 95. Every self-respecting word
processor should be able to read and write RTF (Rich Text Format).
Thereby you can transfer documents in Celtic and other West European
characters *with complete formatting* between Macintosh and Windows.
The MacCeltic character set includes the letters 'w' and 'y' with
various accents (´ ` ^ ¨) in addition to the regular West European
characters. Under Windows 95, you need a Unicode-savvy application
like Word 97.
This file may be included on the Info-Mac CD-ROM.
