Download: http://archive.info-mac.org/text/bible-dictionary-5.hqx
Bible User Dictionary Modules for Common Word Processors:
Enclosed in this file are a series of Bible User Dictionary modules for
use with common word processors.
Modules are enclosed for Microsoft Word, Word Perfect, Nisus, all Claris
programs, and a generic module (text-only) that can be imported into any
other program.
Five different Bible version modules are available for each of the above
word processors:
€ The New American Standard Bible (NASB)
€ The New International Version (NIV)
€ The Revised Standard Version (RSV)
€ The King James Version (KJV)
€ The New King James Version (NKJV)
These different modules are needed because different Bible versions spell certain words differently, especially in regard to proper names and geographical locations. You can use the module (or modules) of the version(s) you regularly use.
The NIV module has some 3300 unique words (that is, words that are not found in normal spell checking programs). The KJV module has well over 5500 unique words. In each case, the modules should make spell-checking your documents much simpler!
Consult your program manual for instructions on installing and/or activating these modules.
PLEASE NOTE that there is a $5 shareware fee to cover the many, many hours it took to construct these modules.
Please send your fee to:
Ron Rhodes
P.O. Box 80087
Rancho Santa Margarita, CA 92688
Thanks.
I can be reached at the following e-mail address: .
