Calculator 1.0 By Scott Garrett
Download: http://archive.info-mac.org/sci/calc/hc ... tor-10.hqx
| | Calculator 1.0 Abstract | |
|_Version_| 1.0 for HyperCard 2.4 or later |
|_Creator_| Scott Garrett |
|__CInfo__| This is a very simple calculator program I wrote with |
| HyperCard 2.4b16. It is mouse-controlled and I also added a |
| feature that will allow you to remember a number for later use. |
| Since this version is my first, it has some bugs in it. |
| Here are ones that I know of right now: |
+‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹{ Bugs } ‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹‹+
| Calculator can¹t calculate problems that contain multiple signs. |
| (In other words, it can¹t, yet, figure out what 12x12-3+14÷2 is.) |
| The workarond to this is to do the first part (like 12x12) then |
| press the ³=² button. Then you would start doing somthing like |
| this: 144-3 {equals} 141+14 {equals} 155÷2 {equals} 77.5. 77.5 |
| would be your answer. (If you don¹t get this, ask me to send you |
| an GIF animation of me doing this.) |
| The data field does not clear after you have done a calculation |
| and pressed the ³=² button. Instead it adds on to the answer. |
| This may be good or bad, so I¹m taking a servey on this: If you |
| think I should keep this ³feature², email me with ³Calculator = |
| Yes² in the subject. Otherwise email me with ³Calculator = No² in |
| the subject. :) |
| Well, anyway, if you have any questions, other bugs, or |
| comments about the Calculator, email me at [email protected] |
| Then, while I come out with another version of it, I will try to |
| remove as many bugs as possible (excpet for the Equals button |
| thing -- that depends on your votes.) :) |
| Scott Garrett | ftp://magarret:[email protected]/spc4_stuff |
