Download: http://archive.info-mac.org/sci/ic-15-ppc.hqx
Intelligent Chaos 1.5 -- probably the fastest chaos engine on earth!
Intelligent Chaos (IC) is a simple tool which allows You to study the
emergence of chaotic behaviour in the logistic equation and related
iterations.
Of course there already exist plenty of programs that makes beautiful
chaotic graphs, but You will never understand chaos theory without
looking at the actual numbers. That is what You can do with IC, in great
detail.
The equation used is a*x*(1-x). The chaotic parameter (a) is given the
default value 3.5699, that is just below the point where chaos sets in,
but the idea is of course that You should let i vary from 2 to 4.
Use Balloon help to get info about the controls.
