Download: http://archive.info-mac.org/nwt/util/serial-key-102.hqx
SerialKey 1.02
This package allows the use of PC/Macintosh keyboards with the newton. To use
this program yo need a serial cable to connect the newton to your computer
and a standard communication program. You need to configure the communication
program with the following setings:
9600 bauds, 8 bits data, 1 stop bit.
To use the keyboard: tap on the SerialKey icon in the extras drawer, tap on
any entry area and star typing, also you can drag the program window to any
location, the program remember the location for the next time that you use
it.
Guillermo Zaballa
