Don't Ask ("Do you want to add...") kbd utility
Post by Info-Mac » June 8th, 1995, 9:00 am
Download: http://archive.info-mac.org/nwt/util/dont-ask.hqx
Keywords: keyboard, prompt, source, Newt
Don't Ask (Don't Tell) is a simple, tiny app (autopart) that adds a button (at
lower left) in the standard Newton keyboard so that you can turn off/on the
"Do you want to add..." prompt, which you may find annoying or sometimes
desirable...
When dot is hollow (default), words pass through to the dictionary prompt.
When dot is solid, the dictionary prompt does not appear (it's
blocked/overridden).
This Newt source file (dontask.nwt) and the associated Newt-generated
package (DontAsk.pkg) are shareware ($5)
Steve Weyer
http://www.netaxs.com/~weyer
