TimeToGoReading; a newton ap
Download: http://archive.info-mac.org/nwt/app/tim ... eading.hqx
This newton package (made with Steve Weyer's newt) tells you the time
to go to finish a task based on your previous performance. In particular,
you can use it to project time to finish reading something.
Instructions and motivations to use included in this small file stuffed
and binhexed. Shareware, only $5 if after trial you decide to use it. May
be distributed, but only with TimeToGoReadme bbedit text file.
