Rate-A-Course for Newton
Download: http://archive.info-mac.org/nwt/app/rate-a-course.hqx
Did you ever sign up for a class, start attending it, and then remember
that a friend of yours had told you that it was a headbanger, or not to
take it, or that the Prof. was a slavedriver?
Well suffer no more fellow Newt owner!
Assuming you're a true Newt freek and have it with you nearly 100% of
the time, you're probably going to find this piece of stationery quite
useful.
Rate-A-Course lets you keep track of:
€ The Prof's Name (and you can select names directly from the Names soup
if you want)
€ The status of the class ('Breeze',
'Cool','Headbanger','OK','Sucks','Totally Blows' are predefined)
€ When it's offered (predefined: Fall/Spring/Summer Semester,
First/Second/Third/Fourth Quarter)
€ Who recommended the course to you (you can select names directly from
the Names soup if you want) -- this is good so you know who to go back
to thank or otherwise deal with depending on how the class actually
turned out ;->
€ When the class was taken (if you do end up taking it) -- same
predefined periods as when it's offered
€ What grade you received (lots of predefined's, although you'll
probably only use the 'A' selection right?)
€ And a never-ending comments field so you can add whatever you want
(e.g., where you took the course, what the prof was REALLY like, grading
policies, adhearance to the syllabus, tips, etc...)
If you have questions, comments, suggestions, etc., want to make a
donation (US funds), or just want to drop me a postcard saying this
thing saved you from taking a really crappy class, send a note to:
David Greenberg PO Box 307 Highland Park, IL 60035-0307
Internet: [email protected]
