Download: http://archive.info-mac.org/inet/web/cg ... r-10b1.hqx
Kev's PreProcessor 1.0b1 is a WebSTAR Plug-in that allows multiple index files to
be used in WebSTAR. It also can restrict CGI programs from executing unless they
are in folders you specify.
More info available at
Kev's PreProcessor requires WebSTAR 1.3.1 or greater. It
contains code for both PowerPC and 68K processors.
Kevin Hayes
[email protected]
