Download: http://archive.info-mac.org/inet/web/web-free-11.hqx
WebFree 1.1 is a tool that works with existing web browsers to let you
take control over what you see when you visit web sites.
WebFree allows you to be the editor for the web sites you visit. You
can use it to screen out advertisements, unwanted images or links, and
web cookies. The goal of WebFree is to make your web surfing more
productive.
WebFree is a single Control Panel that works with your existing Internet
connection and browser software. Both MacTCP and Open Transport are
supported, and WebFree is designed to work with all major Macintosh web
browsers, including Netscape, Internet Explorer, and Cyberdog.
Version 1.1 adds regular expression support, Kagi shareware
registration, bug fixes, and more comprehensive advertisement blocking.
WebFree is Shareware. See the documentation and Control Panel for more
information. The author can be contacted at [email protected]. The
home page for WebFree is located at: http://www.falken.net/webfree/
-steve falkenburg
WebFree Author
mailto:[email protected]
