Download: http://archive.info-mac.org/inet/web/postcard-10.hqx
Postcard is a web server plug-in that allows your users to send
customized postcards. The user select a graphic, enters some text and a
destination email address on a normal HTML form. The text is written
onto the selected graphic, which is then emailed directly to the desired
address. This eliminates the need for any kind of "pick-up" procedure
normally associated with web postcards.
Postcard will work on PowerPC web servers running WebSTAR 1.3.2 and
higher, or other W*API 1.1 compliant servers. It is fast, and does not
require any additional helper applications (such as Eudora) to handle
the email or the graphic manipulation.
Permission is granted to include Postcard on the Info-Mac CD-ROM. The
latest version is always available at
cjh
