iRemember 2.0 PPC
iRemember 2.0 PPC
Download: http://archive.info-mac.org/inet/web/iremember-ppc.hqx
iRemember is a completely unique application that keeps track of all
of your web browsing history (regardless of the browser you use) and
lets you quickly browse or search through the web pages you've
visited in the past. Forget to bookmark that great web page and now
you can't find it? Do you use Netscape Navigator and wish it kept
your browsing history? Do you use more than one browser (or more
than one Macintosh) and wish there was one place you could go to find
any page you visited? Wish you could find more pages similar to the
one you're looking at? iRemember 2.0 solves all of these problems
and more!
How often have you had to bookmark a page just because you aren't
sure if you might want to revisit it later? iRemember lets you
return to any page you ever visited just by typing a couple of words
that describe the page! Instead of cluttering up your bookmarks
with pages you might never visit again, you can use bookmarks for
your favorite pages and use iRemember to revisit all the rest.
iRemember works by indexing all of the words in every web page you
visit using the Apple Information Access Toolkit (the same engine
used by Sherlock). Later, when you want to revisit any page that
you've ever seen in the past, you only need to type in a couple of
words that describe that page to quickly return to it.
iRemember also keeps an easy to use history by date and time for all
of the pages that you visited, regardless of which browser you used
to visit them. Now, even if you use a browser like Netscape
Communicator that doesn't keep track of your browsing history, or you
switch between multiple browsers, you have one place to go to easily
look for a web page you visited on a particular day. iRemember also
organizes the pages you've visited by web site, making it easy to
return to a particular page at some company, or to just see which
sites you spend the most time at.
To make it easy to search your browsing history, the Internet or your
local hard disk, iRemember will also (optionally) install a
system-wide menu that lets you quickly switch to iRemember or
Sherlock from any application. This menu also adds new functionality
to Sherlock, letting you instantly search for web pages similar to
the one you're currently looking at or search for pages that contain
the currently selected text with a single click. The global
iRemember menu will totally change the way you work with Sherlock.
Version 2.0 of iRemember adds new commands to find similar pages,
view of all the web pages you've ever visited by web site, delete
selected pages, and to rescan all the pages you've visited to find
any that have disappeared and easily update the indexed content of
the rest. iRemember 2.0 also adds the ability to merge indices from
multiple Macs so that you can quickly find a page that you once
visited regardless of whether you were browsing at home or in the
office. iRemember 2.0 now parses the html in the pages you're
visiting for better content indexing and also properly handles all
single-byte languages.
You can get more information on iRemember and our other shareware products at:
http://www.seracsoftware.com/
iRemember is shareware and costs just $25 if you decide to keep it.
