This utility will spool the necessary files to the SPOOLDIR in order to
have a simple uucp file transfer to succeed.
version 1.10:
Better compatibility with UUPC 3,1, solution of some bugs,
addition of a command allowing to see the settings. This
version does not presuppose the presence of the 'STR '
USERNAME neither SEQUENCEFILE. In the case where they would
not be presented the program uses "uucp" and "SEQF". The bug
that did not allow RFT to read the SEQUENCEFILE, seems to
have been addressed by the same occasion. Some
modifications would give a best stability in the
manipulation of character chains. Typing a "C" to the main
menu, make possible to see the value of the main variable
of the program.
version 1.00:
First public release. Have been tested with a Mac IIvx, and a Mac +
using system 7.1, file transfer were acomplished against a Taylor's
uucp system. Many thanks to Mason Bliss for reviewing the docs.
The next version will fix the english language mistakes.
* Robert Pellerin [email protected] *
* Montreal-Nord, Qc Canada fax.: (514) 328-9028 *
