Download: http://archive.info-mac.org/inet/mail/e ... r-11-x.hqx
Max Programming, LLC - eMail Verifier v1.1 June, 18 2002
________________________________________________________________________
Max Programming is proud to present a new release of Mail Verifier, the
very first tool available on the Macintosh platform for batch e-mail
validity checking. (Classic and Mac OS X)
Product Home Page: http://www.maxprog.com/EmailVerifier.html
> Overview
If your database contains incorrect e-mail addresses, this disadvantages
you in two ways. First, you have to put up with annoying
'undeliverable'
messages. And second, you lose the ability to communicate by
e-mail
with your contacts. Email Verifier checks the validity of your
e-mail
addresses without actually sending e-mails. You can use the list of
failed addresses to build a list for a 'please update' campaign.
Email Verifier is a very effective piece of software that can verify
over 10 e-mails per second . It can verify single e-mails or huge
lists. (eMail Verifier is multithreaded, providing high speed verifying)
eMail Verifier is your powerful solution for the standard "message
delivery error." Email Verifier verifies every e-mail address from a
given mailing list, allows to determine 80-90% of "dead" email
addresses.
eMail Verifier works on the same algorithm as ISP mail systems do.
Addresses for e-mail are extracted from a Domain Naming Server (DNS)
and eMail Verifier tries to connect with SMTP-servers and simulates the
sending of a message. It does not send the message though - eMail
Verifier disconnects as soon as the mail server informs the program
whether the address exists or not.
eMail Verifier can save time and money for businesses who send
newsletters to their clients, nonprofit organizations who send
bulletins to their members, or any person or business that needs to
maintain a clean e-mail contact list.
eMail Verifier is dedicated for system administrators, webmasters,
programmers as well as for those advanced users who have their own
mailing lists and would like to keep them up-to-date.
> Key features
- Batch verify big amounts of e-mail addresses.
- Check e-mail addresses for a valid Mail Exchanger.
- Check each e-mail address validity with its MX server.
- Sort all e-mail addresses by domain to speed all tests.
- Fast multi-threaded engine. (Speed depends on your connection)
- Native version for Mac OS Classic and Mac OS X.
> Price
eMail Verifier is a $24.90 only shareware!
> Trial version download
You can get eMail Verifier from:
Classic: http://www.maxprog.com/shareware/eMailVerifier.sit
MacOS X: http://www.maxprog.com/shareware/eMailVerifier_X.sit
> What's new
[New] Verifier is now Mac OS Classic compatible.
[New] Preferences panel. Almost everything can be set:
- Bandwidth
- Threads from 1 to 10
- Connection Time-out from 10s to 60s
- Retries from 1 to 10
- UserID for 'HELO' command
- MX Lookup system
- RCPT on VRFY failure
- Sender e-mail for RCPT test
[New] Support for Mac OS X Address Book address drops.
[New] Support for Entourge '.VCF' file drops.
[New] Internal MX look-up system.
[New] RCPT command sent when VRFY unimplemented.
[New] Lookup get all MX records and sort them by preferences.
[New] Different MX server used on retry (when available).
[New] Each verifier connection batch verify same domain addresses.
[New] Status bar shows progress and retries.
[Upg] New SMTP errors handlers when VRFY command not available.
[Upg] 550 SMTP error enhanced handler.
[Upg] Better time-out management. General application time-out.
[Upg] Multiple file drop support.
[Upg] Status field updated according to process.
[Upg] Domain sorting progress.
[Upg] Drag'n'drop supported between list and single entry.
[Upg] List entries can be removed with the delete key.
[Upg] New application icon.
[Bug] Double SMTP commands sent on 550 error.
Keys: [New] = New Feature
[Opt] = Optimization
[Bug] = Bug Fix
[Chg] = Changes Previous Functionality
[Upg] = Enhancement
See enclosed documentation to find out more about what eMail Verifier
can do for you ! Thanks for supporting eMail Verifier.
