ConMail 1.3.1b0
ConMail 1.3.1b0
Download: http://archive.info-mac.org/inet/mail/c ... -131b0.hqx
ConMail is a simple POP3 email client that will periodically check
whether you have waiting email. In case you do, you can use it to launch
your email client. ConMail supports an unlimted number of email accounts.
I have written ConMail because I liked some of the already existing
Macintosh programs that feature similar functionality. Unfortunately, I
do not like the way they display information. Moreover, I could not use
them as they were shareware and I did not feel like paying for them.
Therefore, I decided to write my own program and after some work I came
up with ConMail.
In order to run ConMail you need a PPC Macintosh with Appearance, Open
Transport and Navigation Services installed. If you are running Mac OS
8.5 (Mac OS 7.1?) or later, ConMail should run without any problems.
ConMail is released as public domain.
The source code is included.
No virus infections were found - checked with Disinfectant 3.7.1.
To find out more about ConMail go here:
