Two Utilities for Eudora
Post by Info-Mac » August 25th, 1999, 9:00 am
Download: http://archive.info-mac.org/inet/mail/cef-esm.hqx
Curmudgeon's Eudora Fixer and Eudora Sound Mover: Enhancement utilities for
Qualcomm's Eudora email client. CEF allows changing the Status column of
Eudora Pro 4.0 or later to your choice of the icons or the characters.
Selectable font, size, and style are used to create icons which are then
installed into Eudora; you can also change the characters which will be
used to indicate message status. ESM allows adding and removing sounds to
Eudora (Pro or Light, v3.1 or later), which can then be used as alert
sounds for mail arrival or problems. Sample sounds are included. Shareware;
