Download: http://archive.info-mac.org/inet/html/c ... ro-250.hqx
Color Picker Pro is a small drag and drop savvy application that aids in
finding color hex values for use with HTML production. Color Picker Pro is
more than just a RGB to hex converter however! It can literally pull
colors out of windows, icons and Desktop backgrounds. If you can't find a
color that you're interested in using the former method, you can just as
easily utilize any of your System-level color pickers a la the Color Picker
Pro application. Once you've found the color you want, you're only a
click, menu choice or key combination away from pasting your hex value into
any text-based HTML editor. Color Picker Pro will also allow you to store
frequently used colors, undo and redo color changes as well as finding the
nearest Netscape 216 Palette color.
System requirements:
* System 7.5
* Power Macintosh
* Drag and Drop Functionality
* 16 or 32 bit color preferred
For more information, please read the Read Me file enclosed, or visit our
Web page:
http://www.rootworks.com/cpp
Mike McNamara
Rootworks
