MacTCP patch
MacTCP patch
Download: http://archive.info-mac.org/inet/conn/m ... -patch.hqx
--========================_18559790==_
Howdy,
This is a little application that will alter the MacTCP driver to
incorporate Peter Lewis' patch. You will need a virgin copy of MacTCP,
version 1.1.1 for this process. MacTCP 1.1.1 is not included in this
upload -- it is a commercial product. I also understand that this problem
is fixed in MacTCP 2.03 and the upcoming MacTCP 3.
Please report any problems to [email protected]. Many thanks to Peter for
providing the patch information in the first place and Michael Hecht for
the splendid utility ResCompare that compiled this patch.
Patch Description
(Stolen and edited from a recent discussion on Nuntius-L)
>Here's how to make the hack:
>Make a copy of MacTCP
>Open the original with ResEdit
>Double click the DRVR icon
>click the entry, and choose Open using Hex Editor (*** HEX EDITOR! ***)
>choose Find Hex (cmd-F I think)
>Enter: 3542 0210 E34A D441 302A 021A B440 6A04 3400 600A
>Find the 302A 021A in the middle, select that, and type 303C 0BB8
>save and close all the windows
>restart.
>Grab a copy of MacTCP Watcher, and make sure its not doing too much
>retransmission. Too much is defined as more than about 5 or 10% probably.
> Peter.
>It is supposed to fix the retransmit bug that has been bothering users with
>"slow" serial lines, usually via modem. It has worked fine for me, although
>it is hard to tell when something suddenly works as expected :-)
>Good luck,
>Klaus
Cheers, Igor
Content-Type: application/mac-binhex40; name="MacTCP=_patch"
