InterSlIP Timer v. 1.5.1
Download: http://archive.info-mac.org/inet/conn/i ... er-151.hqx
It is a utility application to be used
with InterSLIP that allows you to keep track of how much time you spend on
your SLIP account. InterSLIP must be installed on your computer for it to
work. InterSLIP Timer requires System 7.0 or later.
Version 1.5.1 corrects bugs identified in the previous version. It has a
globally floating timer window. System 7.1 or later is required to use the
globally floating window.
Thank you,
Eric Preston
