Infinity InterSLIP 1.0.2 CSM
Download: http://archive.info-mac.org/inet/conn/i ... -strip.hqx
by Troy Gaul, Infinity Systems
Infinity InterSLIP is a module for Apple's Control Strip that allows you to
control an InterSLIP connection. In order to use this module, you must have
InterSLIP installed and have it properly configured to connect to a SLIP
host.
Clicking on the icon will display a popup menu. The top item shows the
current status of the InterSLIP connection. The middle item allows you to
open the InterSLIP Setup application, and the bottom item allows you to
connect or disconnect from the selected SLIP host (the one that is
hilighted in the InterSLIP Setup application). The icon will also change to
display the current status of the connection.
Changes since version 1.0.1:
- Changed address and e-mail information.
