Download: http://archive.info-mac.org/inet/conn/f ... tic-21.hqx
Fetch-O-Matic (v 2.1) is a new approach to automated website maintenance
via FTP. Fetch-O-Matic allows web authors to freely create and update files
locally without needing to keep track of their work, and then automatically
catalog the alterations and update the website.
Fetch-O-Matic differs from other available synchronization and maintenance
schemes in that it does not require any local machine to have a complete
site copy. For example, one might decide to grab a few pages and change
them (and/or add some new files) from a Powerbook. Later, the site copy on
the primary machine can be quickly brought up-to-date with just two clicks
- without having to remember what was changed or open the Powerbook.
Fetch-O-Matic is extremely easy to use. Novice web authors in search of a
simple way to update a personal web page won't be intimidated by its power.
Experienced hands will find that previously dreaded operations such as
multi-file search and replace, with the subsequent headache of tracking
down and uploading scattered altered files, are rendered painless. Transfer
errors such as uploading/downloading to the wrong directory are a thing of
the past. If several people are maintaining a site they are protected from
treading on each other's updates.
Fetch-O-Matic was conceived and developed to fill a need in servicing a
large site (http://www.filmscouts.com). Uploads and downloads of thousands
of files at once have been performed with ease. But even on a site with
just a few pages, Fetch-O-Matic will ease the updating chores.
Fetch-O-Matic requires Dartmouth's FTP client "Fetch", AppleScript, the
scripting addition Jon's Commands, and, optionally, Alessandro Levi
Montalcini's "List Files" (providing a significant speed improvement for
large sites), all of which are readily available online. Fetch-O-Matic runs
on any Mac OS machine with reasonable (8mb+) RAM running System 7 or 8. It
runs in the background. It is shareware with a single-user license fee of
$20. There is a free 30-day trial period.
The complete documentation is available online at the Fetch-O-Matic home
page, http://www.filmscouts.com/software/fom.html
Version 2.1 adds new features (most significantly, continuous unattended
operation and the ability to add to an upload in progress), and works
around a bug in Jon's Commands 2.0.3.
