Download: http://archive.info-mac.org/inet/conn/a ... tml-11.hqx
Anar2HTML 1.1 by Giovanni Giusti ()
Required OSAXen: File I/O (From the Script Tools Suite), File Commands,
Numerics, String Commands, Scripting Components (from Apple), ACME Script
Widgets (required to sort the list -- comment the relevant lines).
This applet transforms Anarchie and Fetch bookmark files into HTML files.
It saves the result as a random-named file on the desktop (if any of you
can improve on this, you are welcome).
To use, drop a bunch of Anarchie and/or Fetch bookmark files on the applet.
You can also drop a mixture of the two.
Changes since v.1.0: added support for Fetch files. Made some nicer HTML.
Duel S.p.A.
Via G. Dandini, 15
00154 Roma (ITALY)
Tel. ++39-6-5743826
Fax ++39-6-5759368
e-mail
