WebSynch 1.1.1
WebSynch 1.1.1
Download: http://archive.info-mac.org/inet/web-synch-111.hqx
WebSynch is an easy-to-use FTP (File Transfer Protocol) client program
for Macintosh specifically made to simplify updating Web sites. It
allows synchronyzation between a local folder on a mac with a directory
on a FTP server.
WebSynch uses the FTP protocol (File Transfer Protocol) to transfer
files and can thus also be used to download FTP sites (see Usage
Examples). WebSynch combines the ease of use of the Macintosh interface
with a powerful FTP engine. The result is a unique program which becomes
essential if you often update your Web Site or want to keep track of new
files on a FTP server.
Here are some of the features of WebSync:
very easy to use Finder-like Interface. fully threaded synchronization,
allowing to work on other things during this time. Use of Internet
Config for default FTP server, FTP proxy, file type mapping (WebSynch
can function without IC but it works much better if IC is installed).
Supports a wide variety of FTP servers, works with all popular FTP
servers like wu-ftp, NetPresenz and Windows NT FTP. Customisable with a
set of useful preferences. Mirrored/Non mirrored Download and Upload.
(to come) Continue transfer of the file if the transfer was canceled.
Various synchronization modes using the file date and/or the size. And
last, but not least, Ability to Up/Download only the files that have
changed.
