SherlockSets 1.0b7
SherlockSets 1.0b7
Download: http://archive.info-mac.org/inet/sherlock-sets.hqx
SherlockSets 1.0b7
I have wrote this app to enable sets for Internet searches with
Sherlock. Sherlock is cool but when you have plenty of plug-ins in the
Internet Search Sites folder, it's a mess to look for the appropiate
sites to check.
It's freeware, please spread the word!.
To create or modify sets:
- Launch SherlockSets
- Select "Edit sets" from the "Sets" menu
- Create, delete or edit sets.
To use a set
- Launch SherlockSites
- Select the set name from the pop-up menu
- Press the "Launch Sherlock" button
The application creates another folder in the System Folder named
"Internet Search Sites(Disabled)" and moves the disabled files from
"Internet Search Sites" folder to it.
Known bugs:
- Only works in USA version of MacOS 8.5, I think that localized versions
will name "Internet Search Sites" differently. To be fixed in future
releases.
You can always download the latest version at:
http://www.omniasc.es/freeware/SherlockSets.hqx
Please send comments to [email protected]
Best regards
Guillermo Zaballa
