DownloadAssistant 2.6.3
Download: http://archive.info-mac.org/inet/downlo ... nt-263.hqx
With the permission of the author, Fabrice Bianchi
I submit the neat little utility DownloadAssistant to the Info-Mac archive.
It should fit neatly into the comm/inet directory.
From the readme file:
Overview
With this program you can start your downloads using any protocol
(ftp, hotline, carracho, http,Š) and any application (Internet
Explorer, Netscape, Hotline Client,Š) and leave the computer alone
securely. DownloadAssistant will automatically disconnect, then
activate sleep or shutdown.
DA helps prevent pirate intrusions into your system by reducing
useless connection time.
You can set the english speech synthesizer so DownloadAssistant will
give you audio feedback of the download status (very useful if you
are away from your computer!) This function works with DA in
foreground or background.
DA can expand files automatically with Stuffit Expander after
disconnection and before shutdown. Saves time!
It can generate a helpful log file to record what it did for you and when.
