Retroscan 1.0
Retroscan 1.0
Download: http://archive.info-mac.org/gst/grf/psh ... can-10.hqx
RetroScan is a professional quality PhotoShop Plug-In that simulates the effect
of rescanning a noisy TV signal. It provides an easy way to achieve the
fashionable "cyber punk" effect for print, multimedia, and video.
RetroScan has the following controls:
Signal Boost - Adjusts the "gain" of the video signal
Snow - Adds noise as if the UHF signal was fading
Scanline Size - Sets the scanline height to 1,2,3, or 4 pixels
Scanline Contrast - Adjusts the amount of scanline enhancement
Ghost Image - Toggles a faint ghost image 40 pixels to the right
Ramp Edges - Makes the vertical border look more like a TV
Generation - Cycles through the filter 1,2, or 3 times
If you have any questions, comments, or bug reports send them to :
If you like and use RetroScan, please be sure to register your copy by sending
$20 to:
Deep Devices
P.O. Box 620038
Newton Lower Falls, MA 02162
Registered copies of RetroScan will include additional neat stuff.
