Download: http://archive.info-mac.org/gst/grf/vec ... or-01b.hqx
VectorFileConvertor for MacOS-X
from Lindesay Electric
(c) Andrew Lindesay 2002
Latest versions, contacts etc... -- visit:
http://www.lindesay.co.nz/
To install, copy this application to your /Applications
folder. Double click and review the instructions in
"Help".
Many Windows applications can export or save to WMF files.
WMF stands for "Windows Meta File" and is a vector and
bitmap graphics format. Unfortunately, this format is
only really common on the Windows platform. Hence this
utility is able to take a WMF file and export it to PDF
such that MacOS-X applications can render and use the
drawings and images.
There are some limitations in this conversion process,
and this is only a first beta. If you have any
difficulty converting your WMFs, we would like to hear
from you -- ensure that you can build a test case that
is less than 256 kilobytes in size and get in touch with
us on .
Please check http://www.lindesay.co.nz/ for notes or new
versions that might pertain to your problem.
