Image Sizer 1.0 - a simple Mac OS X image viewer and HTML 'img'
Download: http://archive.info-mac.org/gst/grf/image-sizer.hqx
Image Sizer is a simple image viewing program for Mac OS X which
shows the size of each image and will create an HTML 'img' tag for
it. I wrote it because none of the simple image viewing programs I
have shows the size, and it's sometimes a hassle to open a
full-featured image editing program application just to find out the
dimensions of an image to put in the HTML. For convenience I also
added a button which would copy the full img tag to the clipboard,
complete with width, height, src and alt filled in and the border set
to 0 the way I like it.
How to use:
To use Image Sizer, just drag an image file onto its icon, open an
image from the Open command in Image Sizer's File Menu, or drag an
image file onto the area on an existing Image Sizer window where an
image is displayed. If you want to use the image in an HTML document,
change the description from the default if you like (the description
will appear in the 'alt' attribute of the 'img' tag) and press the
'Copy img tag' button. Paste the tag into your HTML document and do
what you like with it.
