Uploading CivEditor
Demos, tips, editors, and anything that goes with commercial entertainment software.
Uploading CivEditor
Download: http://archive.info-mac.org/game/com/civ-editor.hqx
This is a program which patches civilization to do many things.
I am Robin Emig [email protected]
This program simply applies a series of cracks that have been collected
since Civilization came out. These all work on Civ 1.08. The one problem is
that some cracks crack the same area that others do making things unreliable.
To be on the safe side don't crack two things that are similiar, such as Everything
cost $0 and everytime you buy something you get $32000.
If you apply many cracks
at once and not all of them take, try doing one at a time.
Also it would be wise to make a copy of the Civ app before applying these cracks
Here is a list of the cracks and their actions:
buy=32000 Everytime you buy something you get $32000
Sell=32000 Everytime you sell something you get $32000
NoLoseMoney You don't loose money each turn
ClearMap You get to see the entire map
NoWarming Stops Global warming
WinOffense Win every offensive battle
NoFoodShortage Your people don't die due to food shortage(cities no grow either)
Moses Troops can walk on water ( This one has problems with others)
SailOnLand Boats on land (The most powerful, less cheat one I like)
Tech1Turn Each tech takes one turn ( computer gets it too)
Infiniteflight Airplanes don't run out of feul ( This one has problems with others)
Cities on h20 Cities on water ( pretty lame , max size is ?? 2)
NoQuestions Kills that anoying test of your leadership
NoCopyProtection Same as above??? I have no idea
Thanks to the person(s) that originally discovered the cracks, ? Nemo ?
I am not responsible for anything unforseen problems this program may cause.
If you like this program and would like to see more of its kind
please send me $5.
Robin Emig
4010 Jefferson St.
Napa, CA 94558
If you would like to report a bug or have any comments or questions please
send snail to above address or email at [email protected]
p.s. I hate writing docs so if these are too short or too mispelled too bad.
________
