Download: http://archive.info-mac.org/game/brd/he ... er-221.hqx
If you are board with the Quests that came with the Hero Quest game by
Milton Bradley and you don't want to go out and spend 10 dollars on a
new quest pack then you have come to the right place.
Hero Quest Designer is made especially for the people who don't want to
spend a lot of money or are sick of playing old quests. With Hero Quest
Designer you can create your own quests quick and easy. With the full
version you will be able to design, save, and print out your own quests.
If you get board with the ones you make then you can go and make more.
You will need HyperCard 2.x to run this.
Check out Prisim's web page at:
www.geocities.com/SiliconValley/Vista/6187
