Zippier Zip 5.0.3 - remove the OK message from Iomega Guest
Download: http://archive.info-mac.org/disk/zippier-zip-503.hqx
Program: Zippier Zip 5.0.3
Author: Alessandro Levi Montalcini
Price: Freeware
Download: http://www.montalcini.com
Zippier Zip is a free patcher that allows you to modify the
original Iomega Guest 5.0.3 utility for the Macintosh, which
ships with all the new Zip drives.
The patched Iomega Guest application no longer displays a
message when the driver is successfully loaded, so you don't
have to click OK or type Enter every time you load the driver
after startup.
New in 5.0.3:
- Updated for the new 5.0.3 drivers from Iomega.
