Trash€Desktop is a freeware drag and drop utility for rebuilding the
Desktop.
It sets the files ³Desktop DB², ³Desktop DF² and ³Desktop² to visible and
then move them to the Trash.
Just drag and drop any unprotected local disk and then restart the Mac
for rebuilding fresh new Desktop files.
Version 1.1.4 fixes a minor error in the Preferences dialog.
