SysCompare 1.0.0
SysCompare 1.0.0
Download: http://archive.info-mac.org/disk/sys-compare-100.hqx
With SysCompare you can check, what an application installs into the system
folder. Simply click on the upper button, quit SysCompare. Install the
application start SysCompare again, click into the lower button finished!
All new Files are listed up in a list.
