QuickFind 3.1
QuickFind 3.1
Download: http://archive.info-mac.org/disk/quick-find-31.hqx
Offers string, boolean and regular expression search for files and folders
on local volumes, and text and regular expression search within contents of
files. Powerful filtering, designated search areas and a superb PPC search
engine make this the fastest search utility for general use.
New in this version: searches for regular expressions as well as text
within contents of files, and for full as well as partial string names.
Fixes three bugs. Several interface improvements. Faster.
Requires OS 7.5-9x and three scripting additions (osaxen): Akua Sweets,
Dialog Director, and Find Document, all at Info-Mac.
Free.
User comments on previous versions:
"Fantastic . . . Powerful . . . unbelievably fast . . . Thanks John! . . .
great work, fine and easy to use [author, Find Document osax] . . . a
sophisticated application . . . powerful! [MacScripter] . . . competent
program . . . lightning fast . . . a gem! . . . one of his best efforts . .
. makes searching a pleasure . . . even gives Sherlock a run for its money
. . . capable program . . . works solidly. Bravo! . . . lean, mean and
stable . . . the documentation is wonderful . . . fast and elegant . . .
quite fast . . . beautiful application . . . Great Stuff . . . outstanding!
. . . truly a pleasure to use . . . Many thanks . . . quick and neat . . .
Works like a charm. Thanks for a great product! . . . illustrates an often
sought-after routine [MacScripter] . . . wonderful search options simulta-
neously and easily accessible . . . pretty damned good . . . I really like
every feature . . . very impressive, indeed . . . very useful utility . . .
Excellent . . . QuickFind is so stable and has such a nonintrusive
footprint, particularly when you use sideways-collapse at the edge of your
monitor, that you might as well put it in your startup folder."
