PCText 1.0.5
PCText 1.0.5
Download: http://archive.info-mac.org/disk/pc-text-105.hqx
Author: Jesse C. Wood
PCText 1.0.5
Copyright©1998, Jesse C. Wood
A conversion utility that translates PC text formats to the MAC.
Simply drag the PC document that you wish to convert into PCText, and
save a translated copy to the Mac!
New in this version:
-Drag&Drop functionality,
-Quicker conversion engine
-Progress Bar
-Menu interface
-Standard file access capability
-Fixed closing bug
-Fixed translation bug
This program is freeware. It may be included in CD-ROM packages, etc.
without my permission, so long as all documentation is included.
REALITY CHECK:
Under NO circumstances is the author of PCText 1.0 responsible for
damages caused by the use of PCText 1.0. Use of this program is done so
at your own risk.
