MacSlack 1.0
MacSlack 1.0
Download: http://archive.info-mac.org/disk/mac-slack-101.hqx
MacSlack is a freeware drag and drop application that calculates the
amount of wasted "slack space" on Macintosh disk. It can also predict
how much space would be regained by splitting a drive into smaller
partitions or by converting a disk from HFS to HFS+ format. MacSlack
requires 500k of free memory and System 7 or newer. It is compatible
with MacOS 8.1 and HFS+ as implemented in MacOS 8.1 (compatibility with
HFS+ in future MacOS releases which use more HFS+ features than MacOS
8.1 is unknown). The home page is:
http://www.pobox.com/~ericb/software/macslack/
Eric Bennett, [email protected], Cornell University Biochemistry Department
http://www.pobox.com/~ericb (Follow "About Me" link for PGP public key.)
