Kill Cache v3.0
Kill Cache v3.0
Download: http://archive.info-mac.org/disk/kill-cache-30.hqx
Kill Cache v3.0 is a $5 shareware utility that allows users to delete any
files or folders at specified intervals. This is especially usefull for
people who use multiple browsers with caches, or just wish to clean out
certain files on their hard drive periodically.
New features include an administrator lock-out device, detailed file/folder
information, drag-and-drop support, and better error handling.
The Kill Cache homepage is at:
http://207.23.27.2/killcache
There you can download the 68k and PPC versions, as well as archives without
the manual.
