Icon Begone 2.0 fat
Icon Begone 2.0 fat
Download: http://archive.info-mac.org/disk/icon-begone-20.hqx
How to use it-
1. Click the, "Add" button.
2. Add all of the folders you want
--Note, this application resolves aliases and does not
remove folder Icons.
This application does search all of the sub folders.
3. Click on the "Start" button
4. The application will think for a minute then display a
progress bar.
5. When the dialog dissapears, all of the custom icons in all of
those folders are gone. Select quit or add new folders.
6. If you accidentally add a folder and want to delete it from the
list, click on it's name and hit the delete button.
You can figure on about 0.022 seconds for each file on an 80 mhz machine.
I tested this app today and it cleared 2000 files in 44 seconds.
You must have apperance manager to run this application.
