Download: http://archive.info-mac.org/disk/ghost-hunter-15.hqx
What is Ghost Hunter?
Ghost Hunter is a utility that is designed to allow users to quickly and
efficiently delete, move and change the visibility of invisible files and
folders, Ghost Hunter also includes many other rich features for file
management. One major enhancement of Ghost Hunter is its ability to quickly
find the application that created the file you have selected, no more
comparing creator types!
[screen shot - http://www.mb-software.net/screen_shots ... hunter.gif]
Ghost Hunter incorporates the point and click features of Mac OS side by
side with advanced features such as key combinations for speedy volume
navigation. Some advanced features of Ghost Hunter include: the ability to
see just invisible files or visible and invisible files; detailed
information on every file and the ability to easily find the application
that created that file.
Ghost Hunter incorporates the ability to list detailed information on any
the file that is double clicked, including: Name, Size, Date Created, Date
Modified, Path, Creator Type, File Type and its creator application. Find
all the information you need with a few simple clicks!
Ghost Hunter will run on any PowerPC Macintosh with Mac OS 7.6 or later.
Ghost Hunter is $10.00 shareware. It is only available straight from
Monkeybread Software at:
http://www.mb-software.net/downloads/ghost_hunter.sit
Important Features
€ Fast navigation
€ One of the only available ways to delete, move invisible files
€ Enhanced with features for power users
€ The ability to delete multiple files at once
€ Extensive information on any file
€ The ability to see just invisible files or visible and invisible files
€ A extensive support website and support for any user
€ A comprehensive manual
€ The cheap shareware price of just $10.00!
€ The Monkeybread Stamp of Quality
Availability
Ghost Hunter 1.5 is only available through: http://www.mb-software.net/
If you have any questions please contact: [email protected]
About Monkeybread Software
Monkeybread Software was founded in 1998 with the idea of bringing quality
software to Macintosh users worldwide. Monkeybread Software was the
originally established by Matt Ronge in the hopes of using his programming
talents to generate a little revenue. Monkeybread Software is now a small
shareware and freeware company.
Contact Information:
Matt Ronge - [email protected]
Software Support - [email protected]
Website - http://www.mb-software.net
