Findfiler 1.0 AS
Findfiler 1.0 AS
Download: http://archive.info-mac.org/disk/find-filer-10-as.hqx
FindFiler by Giovanni Giusti ().
Required OSAXen: "Find Document" (get it at
Other requirements: Scriptable Finder
This is an implementation of the scripting addition "Find Document" by J.F.
Pautex ().
Drag one or more disk icons onto the application, then tell it what to
search for on the disk(s). If you wish, it can open the found file(s) for
you. Otherwise, the Finder opens the folder(s) which contains it/them.
