Drop Rename 3.5
Drop Rename 3.5
Download: http://archive.info-mac.org/disk/drop-rename-35.hqx
Drop Rename performs many different types of renaming operations on files
and folders. It lets you create custom self-running Renamelets, supports
conditional renaming, wildcard search and remove, file numbering,
conversion to DOS naming formats, and much more. Fully multi-threaded so
it runs great in the background and never hogs the CPU. Version 3.5 adds
support for editing Renamelets. $10 Shareware. For more information,
check out our web site at
