CDFinder 3.0.2 68k
CDFinder 3.0.2 68k
Download: http://archive.info-mac.org/disk/cd-finder-302-68k.hqx
CDFinder is a very fast and powerful tool to create catalog files of your hard
disks, floppies, ZIP's and anything else that spins. It has a great user
interface and very useful search functions. CDFinder supports drag&drop and
requires at least a 68020 or PowerPC CPU. While System 7 is required, CDFinder
is also fully compatible to MacOS 9.1. A special feature is the
multi-lingual user
interface (German/French/English/Italian/Swedish/Chinese).
http://www.cdfinder.de
Now there is also a version for windows:
CDFinder 3.0 uses a new powerful catalog file format that will
contain a lot of additional information. So far, every item in a
catalog can have a comment and CDFinder can also read the version
info for files.
CDFinder 3.0.2 is a recommended bug-fix release.
This file requires a 68k Macintosh.
Contact:
Norbert M. Doerner
Mozartstr. 16
64546 Moerfelden-Walldorf
Germany
