Dragonsmith 1.1.1
Dragonsmith 1.1.1
Download: http://archive.info-mac.org/dev/src/dra ... 111-cp.hqx
--========================_17225260==_
Dragonsmith 1.1.1
Drag-and-drop application kit for THINK C 5.0 and 6.0.
Dragonsmith lets THINK C programmers easily create drag-and-drop
applications (or "dragons") for use with System 7. It features an
object-oriented class "Dragon" which may be subclassed to provide
any batch-type action desired. All source code is included.
Version 1.1.1 is a bug-fix and THINK C 6.0 compatibility release
only. No new features have been added, and the documentation has
not been changed from version 1.1.
Some of the bug fixes since version 1.1 --
+ Processing is no longer sluggish when drag-and-dropping files
to launch a dragon
+ Files on AppleShare volumes are now handled correctly
+ Launch in System 7.1 no longer results in a crash
Notable features of Dragonsmith --
+ Versatile disk- and folder-opening capability
+ Background processing
+ Extensive documentation (MSWord and text formats)
+ Resource-based Preferences class
+ Template files for quick Dragon subclassing
Three sample dragons with full source code are included.
Dragonsmith is freeware.
Paul Hoffman.
Internet: [email protected]
AFS: /afs/umich.edu/user/n/k/nkuitse
"Dragons do not enter into this story"
Content-Type: application/mac-binhex40; name="Dragonsmith_1.1.1.cpt"
Content-Disposition: attachment; filename="Dragonsmith_1.1.1.cpt"
