Open in Browser 1.1
Open in Browser 1.1
Download: http://archive.info-mac.org/dev/osa/ope ... ser-11.hqx
Open in Browser AppleScript can be used from any location on your computer,
It opens html files from a folder of your choice in your browser. One html file per
browser window. Great for when you have to print out a web site from the browser or you
want to quickly skim through all your pages.
Requires: Netscape Navigator or Internet Explorer, AppleScript, MacOS
Version 1.1 fixes a bug in sub-folder searching. Also makes navigator windows at 640 by 480 instead of default.
How To Use:
1. Run the script (double click on it). Script may ask you where your browser is.
2. Script asks for a folder where your .htm or .html files are located
3. Script asks if it should search sub-folders within folder selected in step 2
4. Script proceeds to open each page in its own navigator window
5. Once finished, the script alerts the user with a dailog. This script does not modify in anyway the files or their file names.
Updated scripts and other cool stuff can be downloaded and seen from:
http://home.earthlink.net/~mnieves
