KeyQuencer Lite 2.5.5
Download: http://archive.info-mac.org/dev/osa/key ... te-255.hqx
KeyQuencer is a utility that lets you create shortcuts (called "macros") that
perform a series of tasks with a single keystroke. Because you can automate
virtually any task with KeyQuencer, you can use it to save hours and hours of
time.
You can use KeyQuencer to:
Launch or quit programs, open documents or folders, or switch applications Type
text or keystrokes Click or drag the mouse Press buttons Choose from menus
Navigate scroll bars, move or select windows, or wait for specific events Copy,
move, rename, or delete files or folders Jump directly to any folder or disk from
within an Open or Save file dialog Copy and paste text from up to ten clipboards
Compress, decompress or BinHex encode files and folders with the StuffIt Engine
Switch printers, mount file servers, unmount volumes, or eject removable disks
Change your monitor bit depth or resolution, or your speaker volume Shut Down,
Restart, Empty the Trash, or toggle Balloon Help Play or pause an Audio CD
Control one or more computers across a network, synchronize the clocks or
clipboards Open or close a PPP connection And much more!
What the Critics Say About KeyQuencer
"Four Mice" -MacUser, January 97
"KeyQuencer offers a lean, mean, inexpensive alternative to CE Software's
QuicKeys, automating your Mac with less memory and for fewer dollars."
-Macworld, September 97
"KeyQuencer feels lean, mean and clean; we doubt anyone would use those
words about QuicKeys." -MacWeek, May 19, 1997
"Binary Software's KeyQuencer is probably the most powerful and flexible
macro program on the market." -Macintosh Daily Journal, April 97
Why KeyQuencer Is Better than the Competition
KeyQuencer is the fastest. KeyQuencer macros execute much faster than any
other macro utility.
KeyQuencer is the most powerful. Over 70 built-in commands let you do
anything!
KeyQuencer is the most reliable. KeyQuencer never, ever, ever crashes.
It's virtually conflict free.
Charles Haspel
Binary Software
