Autostart with power up/down of arraysync installation
ManBehindTheCurtain
Post by ManBehindTheCurtain »
Hi there. Can anyone tell me if there is a way of instead of using the scheduler of the mac-mini to just power up/down the complete installation instead?
When i test this powering down the mac-mini, on start-up there is only one display (display 0) in the array sync display window even if the 2 screens are on and recognised (2 screens with one double-HD file panned).
all the best,
TV
MBTC
Re: Autostart with power up/down of arraysync installation
I’m not sure what a double-HD file panned means. Your computer sees both displays as one large display? If so they will only show up in ArraySync as just one display.
ManBehindTheCurtain
A 3840x1080 apple pro res 422 HQ-file spanned over 2 screens. It works fine starting up manually or with the automatorscript but not with forced power/downpower-plug with remote control. I add a "quit array sync" to the script but works every once in a while. Other times i get an "error opening the preset file"
ManBehindTheCurtain wrote:Hi there. Can anyone tell me if there is a way of instead of using the scheduler of the mac-mini to just power up/down the complete installation instead?
all the best,
TV
MBTC
I can’t say why shutting down with a remote would be any different than shutting down manually. I can’t troubleshoot a third-party remote but if you find a solution please post it here!
