Transfer pics from iphone to ipad
How can i transfer pics and videos from my iphone to my ipad without computer? Chris
Re: Transfer pics from iphone to ipad
Well, you can definitely email them to yourself, then check your email on your iPad and save them to your library.
You can also try Photo Transfer App which has excellent reviews.
You can also use the ipad usb camera kit, plug in the usb camera kit to your iPad, use your iPhone sync cable and plud it into the usb port of the ipad adaptor and tada your photos from your iPhone will appear in the ipad's photo app and transfer away... that is if you purchased the iPad camera kit...
There's also "Camera for iPad" that allows you to use your iPhone or iPod Touch as a camera for an iPad 1. It connects via either WiFi or Bluetooth.
Mark
Mark
markhoward
- 2 MB
You will need the camera connection kit, though.
Plug the CCC USB adaptor into the iPad, then use the regular iphone USB cable to connect the two devices. The iPad will behave as if you are downloading photos from a regular camera. Easy.
You're all referring to the Apple iPad Camera Connection Kit of course. I didn't know you could plug an iPhone into it and it would be recognized as a regular camera.
